ticking engine noise, weird sputter idle sometimes
1 reading
7.5K views 5 replies 5 participants last post by  Deameon
#1 ·
idont know what it could be but, if i start my car up, theres a ticking noise coming form the engine, n it gets alittle louder when i take off, but then it dissappears. also sometimes after i start the car or mayb if i get off the freeway and come to a complete stop, the car kinda sputters alittle as if it is about to turn off? any ideas
#2 ·
The ticking noise is the lash adjusters IIRC. Pretty common among the 4.7's. Mine does it too. As for the sputtering, I can't help you. Mine does it too but I haven't had time to look into what it could be. No codes on mine either and I assume yours has none as well?
#3 ·
i only have a small vacuum leak code, and should i worry about the ticking?
the sputtering is weird, its like its being choked off and about to just turn off.
also theres a weird noise if i come to a complete stop and then accelerate gently while turning the wheel alittle, its only for about 3 seconds and it soulnds like something grinding or like a hinge that hasn't been oiled?any idea,
if its any help at all, i just had my breaks done all around and sparkplugs put in
#5 ·
I know this is an old thread but mine has aticking sound just for a few seconds especially when its cold. Is that normal? As far as the sputtering. I think it could be early signs of a fuel pump. Of course that is only a guess but about 8 months ago mine started doing that once in a while. Then one day I was sitting at my friends house and my Durango was running. It sputtered and then died. Would not start after that. I took it to a mechanic and it was the fuel pump. Cost me 600 for the job. I hope this is helpful and not just useless information for you.
Kevin
#6 ·
Ticking is normal, as for the sputter like its a monster v8 with a harsh idle / about to shut off is normal also.
Its not the fuel pump but just issues with the intake temp and air/fuel mixture. I have had it on the monitor a few times when its done it by driving and coming to a stop. Mostly does it when its just warming up for mine.
Best way I can kind of describe it is the engine slows down and gets to much air and bogs abit and the comp just acts a little funny trying to correct the problem.
It happens in all my tunes and isn't a really big deal.
In my performance tune it can actually shut my truck off when its in reverse in cold weather cause of this.
